Modifed Ender 3 Pro keeps pausing
Printer Model: Ender 3 Pro, Highly Modified
MCU / Printerboard: SKR Mini E3 V3.0
PSU: Mean Well LRS-350-24
Files:
printer.cfg (14.7 KB)
klippy(1).log (3.6 MB)
Host / SBC: BTT Pi V1.2
klippy.log attached
Hello All! I am running into a weird issue. My printer keeps pausing as soon as my printer starts to actually print. I am not sure why, everything seems to be working, but I am not getting errors, minus the communication error at the end. I did rearrange some wires in the electronics box, but I doubt that is causing issues. Please let me know what information you might need.
Thanks in advance!
Hello @Soren.R !
The extruder temp is quite fluctuating and Klipper waits for it to settle.
Have you already run a PID-Tune?
https://www.klipper3d.org/Config_checks.html?h=pid#calibrate-pid-settings
I will do that real quick. Thank you for your feedback!
So I calibrated the extender and was able to print a test print multiple times with no issue, but a different file is pausing it. Nothing changed between the slicing of the files, not getting any errors, or seeing much in the log. Attached are the 2 g-code files in question. First Layer Calibration works fine, Bottom does not.
FirstLayerCalibration-FirstLayer_0.24mm_ABS_Generic Klipper Printer_2m30s.gcode (46.3 KB)
Bottom_0.24mm_ABS_Generic Klipper Printer_40m22s.gcode (727.1 KB)
Here are the logs
logs-20241026-182032.zip (56.6 KB)
A question for clarification:
  • The printer pauses - and works on alter
or
  • The printer cancels/halts/stops/aborts the print
It is pausing. I am able to click resume, and it works for a second or two, then pauses again.
Okay, it’s a hardware issue. I unplugged the screen and it seems to be working fine now. Thanks for your help! Silly thing haha
