Creality Ender S1 Pro
MCU / Printerboard: CR-FDM-v2.4S1_v30
I’ve just connected and set up the Creality Sonic Pad for my Ender S1 Pro.
In order to have a quiter printer using Klipper, I need to know if it’s possible to unplug (or disable) the printer motherboard fan.
Regards,
Marco
I think that, using the Creality Sonic Pad with Klipper, the motherboard on the printer is useless and it is completely by-passed by the Sonic Pad: am I right?
First of all, I wouldn’t do this. Your drivers, and or you board could overheat, and overheating elec is a big no-no. Question, does you motherboard have the option to change the fan output voltage? If so, just spend 15-20 bucks on a quieter one on amazon. If not, buy the quieter fan AND a buck (I think that’s what its called?) converter. Then just follow a tutorial, and viola, a quieter printer.
I actually found that by upgrading the fans on my printer it made it so you can the stepper drivers better.
Hi Blake, thanks for the advice. I’ve just changed some fans with quieter ones but as the airflow is the same I haven’t found so big improvement. For this reason, I thought to detach at least the motherboard fan as I start using the Sonic Pad with Klipper. Anyway, at the moment, to have a quieter printer, my idea is to change the power supply with Meanwell LRS 350-24 as this hasn’t the fan always on but it is temperature-driven. Regards, Marco
