Two Ender 7 + Sonic Pad - One Working perfect
Ender 7
Printerboard: Creality 3D Ender 7 Motherboard_v2.4.S1_32 bit_MS35775_STM32F103RET6
SBC : Creality Sonic Pad
Hello people !
I am quiet new on klipper and i would like to ask for help from people who know much more than me.
I have one problem with one of my Ender 7… Let me tell you problem and i will also provide all files, videos and infos, cos i am really interested to solve this problem.
I have 2 Ender’s 7, One of them is with Cr Touch and Other one With Bl Touch, with them i also got one brand new Creality Sonic Pad, and since i am using few K1 Max printers on klipper i wanted to switch Enders 7 on klipper too.
To be honest i was researching on forums, googled aboud Ender 7 and Sonic Pad, and i didnt get possitive feelings about doing that but i wanted to do it anyway…
So first of all both of Enders had some wierd firmware, touch screen wasn’t responding well, and i couldn’t flash klipper on printer at all…after i spend hours researching i found Stock Ender7 Marlin Firmware, and i flashed both of Enders. After it was done they both worked perfectly, touch screen was faster, they were very silent.
And than i tried to flash KLIPPER and i sucess on both of them, tested benchy’s, and they were perfect.
I started second print ( the same one other Ender is printing in the moment) and after 1 hours problem starts.
One of enders is still printing like i show on the video, working really nice, but the other one get wierd LOUD grinding, blocking noise and started to moving x and y axes so wierd.
I tried to find on google if anyone had same problem but nothing. After that i have take off cover, check all bearings, oil them carefully, check belt tension ( thats why they’re loose on video, ) everything seems fine…
When i was flashing KLIPPER on him i made same copy of files for both, and one is working perfect, other one have this problem, and i am desperate.
PRINTER CFG:
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
microsteps: 32
rotation_distance: 32
endstop_pin: ^PA5
position_endstop: 0
position_max: 260
homing_speed: 80
[stepper_y]
step_pin: PB8
dir_pin: !PB7
enable_pin: !PC3
microsteps: 32
endstop_pin: ^PA6
position_endstop: 260
position_max: 260
homing_speed: 80
step_pin: PB6
dir_pin: PB5
enable_pin: !PC3
rotation_distance: 8
endstop_pin: ^PA7
position_endstop: 0.0
position_max: 300
pressure_advance : 0.520
max_extrude_only_distance: 1000.0
step_pin: PB4
dir_pin: !PB3
enable_pin: !PC3
rotation_distance: 22.84
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
tuned for stock hardware with 200 degree Celsius target
pid_kp: 19.028
pid_ki: 0.919
pid_kd: 98.472
min_temp: 0
max_temp: 265
[heater_bed]
heater_pin: PA15
sensor_pin: PC4
control: pid
tuned for stock hardware with 50 degree Celsius target
pid_kp: 74.146
pid_ki: 1.521
pid_kd: 903.658
min_temp: 0
max_temp: 130
[bed_screws]
screw1: 25, 33
screw2: 230, 33
screw3: 230, 230
screw4: 25, 230
[fan]
pin: PA0
[fan_generic extruder_partfan]
pin: PC6
serial: /dev/serial/by-id/usb_serial_3
restart_method: command
[input_shaper]
shaper_type_x = 2hump_ei
shaper_freq_x = 118.8
shaper_type_y = mzv
shaper_freq_y = 59.4
[filament_switch_sensor filament_sensor]
pause_on_runout: true
switch_pin: !PA4
[printer]
kinematics: corexy
max_velocity: 500
max_accel: 5000
max_z_velocity: 10
max_z_accel: 1000
square_corner_velocity: 5.0
[bltouch]
sensor_pin: ^PB1
control_pin: PB0
x_offset: -56
y_offset: -22
z_offset: 3.57
speed: 20
samples: 1
sample_retract_dist: 8.0
[include timelapse.cfg]
[gcode_arcs]
#resolution: 1.0
[gcode_macro G29]
G28
bed_mesh_calibrate
G1 X0 Y0 Z10 F4200
Does anyone have any idea?
klippy (1).log (108.9 KB)
Video 1 : Watch 1006 | Streamable
Hello @virtualhrca !
Sorry to say: We do not support the Sonic Pad.
I understand that, i am curious about sounds only, not sonic pad…
Problem is, your klippy.log doesn’t help. You may read about that here. So, no point to help.
I would suggest, dump the Sonic Pad. Sorry.
I have readed now and i understand, but i have also realise that my problem is not klipper problem seems, cos i flash stock marlin again but i still get wierd blocking noise…dunno if motors are broken or what, can you watch video please
Too much acceleration and/or not enough current.
Can the head be moved freely when the motors are off?
Yes but its not going smoothly… when I want to move front back its going bit easier than left right… I checked all bearings, all screws, tried to play with belts tension but still when I press home it have this noise and vibrating/blocking weird movements…
And this happend in the middle of perfect print on klipper… other Ender 7 is working fine, 1 hour to finish print, working perfect with sonic pad and klipper
Please guys help me? Any idea where this noise come from? … i have install stock firmware again but its the same
Unfortunately, it is quite hard to diagnose such topics without physical access to the machine.
From your description, it seems evident that your issue is either mechanical or electrical in nature and not a software / firmware / settings issue.
Possible reasons include but are not limited to:
  • Defect in stepper or stepper driver
  • Defect in the wiring to the stepper, e.g. broken or nearly broken
  • Improper alignment of the frame, axes, linear rails that are leading to binding effects
  • Defect of some linear motion components, e.g. linear rails
The only way to really diagnose, e.g. binding axes is to decouple them from the stepper motor and then check if they can be freely moved in both directions.
