Background
Whereas Time too close rather indicates an overloaded / jammed host, this error points to an overloaded MCU
Reasons
- Too high step rate
Potential solutions
- Check for approaching the limit:
- Check the Benchmarks document and find the 3 stepper value for your MCU type
- Check the
klippy.logfile and find lines similar toqueue_step 0: t=72950209107 p=7317 i=28714 c=-29 a=214 - If the
i=xxxvalues are about the same or even lower than the 3 stepper value from the MCU benchmark then too many steps are requested
- Reduce the
microstepssetting of the steppers (typically X and Y) - Reduce printing speed
- Also see Advanced Trouble-Shooting / Graphing Klipper
