Printer Model: Custom
MCU / Printerboard: SKR 3 EZ
I had a hard time figuring this out so this might help some people, hopefully, to get theirs up and running. This will work for the following and maybe others as well:
- SKR 3, SKR 3 EZ
- EBB36, EBB42
- Raspberry 3B+, 4
- Waveshare 7" HDMI Touch LCD
Install Mainsail OS from Pi Imager to SD with option (SSH,Wifi and passwords)
Make sure you have Wifi
apt-get update
apt-get upgrade
- To configure Waveshare Screen
nano /boot/config.txt - Add the following lines
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
- Exit and save as same filename and then to configure touchscreen type:
sudo apt-get install xserver-xorg-input-evdev xinput-calibrator
sudo cp -rf /usr/share/X11/xorg.conf.d/10-evdev.conf /usr/share/X11/xorg.conf.d/45-evdev.conf
sudo nano /usr/share/X11/xorg.conf.d/99-calibration.confand insert the following:
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "73 4007 3976 84"
Option "SwapAxes" "1"
Option "EmulateThirdButton" "1"
Option "EmulateThirdButtonTimeout" "1000"
Option "EmulateThirdButtonMoveThreshold" "300"
EndSection
Reboot
Install KIAUH
cd ~
git clone https://github.com/th33xitus/kiauh.git
./kiauh/kiauh.sh
Update All
Install KlipperScreen
To exit KlipperScreen CTRL+ALT+F1, to get back CTRL+ALT+F2 (if using keyboard attached to Raspberry)
Prepare klipper for SKR 3 EZ
cd ~/klipper
make menuconfig
- and choose following options:
Enable extra low-level configuration options select
Micro-controller Architecture (STMicroelectronics STM32)
Processor model (STM32H743)
Bootloader offset (128KiB bootloader (SKR SE BX v2.0))
Clock Reference (25 MHz crystal)
Communication interface (USB to CAN bus bridge (USB on PA11/PA12))
Can Bus interface (CAN bus (on PB8/PB9))
(500000) CAN bus speed
- Q then Yes then type:
make clean
make
After make is done, download “klipper.bin” firmware from home/pi/klipper/out folder to computer
Rename “klipper.bin” to “firmware.bin” and copy it to the SD card (FAT32) to update the firmware
Load the SD card to SKR then power it (if via USB, no additional steps are needed) and connect it to to Raspberry via USB cable then type:
ls /dev/serial/by-id/ -
Copy the ID number, for ex. usb-Klipper_stm32h743xx_XXXXXXXXXXXXXXXXXXXX-if00
Connect to Mainsail
Type Raspberry IP on browser to connect
If moonraker gives error, add your IP range to moonraker.conf
Download latest printer.cfg from SKR Github or use backup
Update the “mcu” section on printer.cfg with the ID number of the board
Temporarily update min. Temprature for Bed and Nozzle to prevent error (-250 works fine)
Upload the file to Klipper via browser (if no upload option is given, moonraker will require sudo password, enter sudo password for moonraker via browser)
Restart Klipper firmware and everything should work other than specific configurations
EBB36 Setup (DO NOT ATTACH HOTEND BEFORE PROGRAMMING for 1.0 and 1.1)
Go into SSH console and type:
cd ~/klipper
make menuconfig
Processor model (STM32G0B1)
Bootloader offset (No bootloader)
Clock Reference (8 MHz crystal)
If using CANBus communication Communication interface (CAN bus (on PB0/PB1)) (500000) CAN bus speed
make clean
make
Download STM32CubeProgrammer and install on your computer
Put jumper on VUSB on EBB36
Attach USB-C cable to computer and to EBB36
Open the installed STM32CubeProgrammer, select “Open file” tab on top and then select the firmware you downloaded from raspberry (klipper.bin)
On the EBB36, press and hold the Boot button, then click the RST button to enter DFU mode, you can let go of the buttons as soon as you press RST button (Windows makes a sound)
On the right panel of STM32CubeProgrammer, choose port “USB”, click the “Refresh” button in the STM32CubeProgrammer until the Port changes from “No DFU d…” to “USB1”, then click “Connect” to connect the chip
After the connection is successful, click “Download”, after the download is completed, a pop-up window stating “File download complete” will appear, indicating that the burning is successful
Click “Disconnect” on STM32CubeProgrammer and then disconnect USB-C cable from EBB36
Take jumper from VUSB and put it to 120R termination terminal (if EBB36 is the last CAN device on the line)
Put the EBB36 to the side, we will connect it in a minute
Create necessary changes in Raspberry network
Go into console (or SSH) and create a interface for CAN bus can0 by typing:
sudo nano /etc/network/interfaces.d/can0 -
and fill it with the information below (the bitrate and txqueuelen may need adjustment down the line according to your system performance):
allow-hotplug can0
iface can0 can static
bitrate 500000
up ifconfig $IFACE txqueuelen 256
pre-up ip link set can0 type can bitrate 500000
pre-up ip link set can0 txqueuelen 256
Exit and save as same filename and type:
shutdown now -
Create your physical connections:
Cut power to SKR 3 EZ
Choose a thick enough wire gauge to send 24V without losses; that should be good enough for CAN as well (twisted pair should not be very critical for short distances), adjust according to your distance from board to EBB36
PAY ATTENTION! To your 24V and GND connection on the CAN bus, CAN H goes to CAN H and CAN L goes to CAN L
Attach cable to EBB36 and to SKR 3 EZ (at CAN FD port)
Do not change USB/CAN FD push button on SKR 3 EZ, it should be at high position (USB)
Bring everything together
Give power to SKR 3 EZ
Attach USB from SKR 3 EZ to Raspberry
Give power to Raspberry
After power on, in console/SSH type:
~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0 -
You should see two canbus_uuid codes, the first one is for the SKR 3 EZ, the second one is for the EBB36
Open up your browser and call mainsail
Under MACHINE, upload a .cfg for the EBB36 (you can use the one provided by BTT and their Github)
Edit the EBB36 config, temporarily update min. Nozzle to prevent error (-250 works fine)
While there, change the [mcu EBBCan] from serial to canbus_uuid: XXXXXXXXX (YOUR EBB36 CAN ID)
Save and Close
Open up printer.cfg, change the [mcu] from serial to canbus_uuid: XXXXXXXXX (YOUR SKR 3 EZ CAN ID) and insert an “include” line to include your EBB36 configuration at the top of printer.cfg, something like:
[include sample-bigtreetech-ebb-canbus-v1.2.cfg] -
Save and Restart
That should do it!
