Support for Hybrid CoreXY
Printer Model: Vcore3.1 to Vcore 3.2h
MCU / Printerboard: Octopus Max
Host / SBC rPi4
klippy.log - Not necesary
Hi
I’m in the process of updating my printer, and the kinematics are changing.
The previous version, Vcore 3.1, is (was) a coreXY.
But… After the update, Vcore 3.2H becomes a Frankenstein’s monster, a HybridXY. I think Makeforge printers use a similar kinematic.
However… when looking into how to configure it, I read (at least I did before; I don’t know if they support it now) that Klipper doesn’t natively support this kinematic, and I don’t want to use RatOS. It’s a very customized distribution, with many links and difficult to follow if you want to change something. I’d like to continue as I am, with Fluidd and Klipper.
I have several questions:
  • Does Klipper already natively support the kinematics of Vcore 3.2h?
  • Are there any plans for it to support it in the future?
  • This idea is possible… (take that kinematics and install it on a regular Klipper, or install RatOS and use my current configuration files, keeping the new kinematics)
  • What other options do I have? (To avoid using RatOS and still have that kinematics)
You have to use generic_cartesian, it should support all possible kinematics, corexy & etc.
Old kinematics code here is for backward compatibility. to not break existing confings.
-Timofey
Where i can find info for use these model?
Well, there is documentation and some posts on the discourse.
I think I will write the example generic CoreXY config and make a PR.
Then, later, it can be reused to define additional motors to make it work as a hybrid.
I guess, here is some example: Issue with hybrid_corexy
-Timofey
I think I’ll try another approach. I’ve looked at the post and it’s not clear to me…
Would this other approach be possible? I suppose so, but…
  • Install RatOS, the Ratrig fork of Klipper, which supposedly has support for the Hybrid CoreXy.
  • Delete all the *.cfg configuration files (there are dozens) except for those related to the printer configuration, which I think are in [printer].
  • Copy my current configuration files.
  • Adjust the automatic update paths, leaving only the Klipper one, and the rest only the ones I currently have.
Do you think this might work?
I did an example CoreXY anyway.
Where RatRig style hybrid probably should work with additional:
[stepper stepper_y0]
carriage: carriage_y
[stepper stepper_y1]
I don’t quite understand this machine definition thing… I’m putting what I think it is here, and please correct me if I’m misunderstanding anything.
  • To start configuring a 3D printer in Klipper, you have to define it.
  • To define the machine’s characteristics, you do it under the [config] section of the *.cfg files.
  • One of the most important definitions is the machine type, which is done in [config] kinematics:
  • Kinematics can be (cartesian, corexy, corexz, hybrid_corexy, hybrid_corexz, generic_cartesian, rotary_delta, delta, deltesian, polar, winch, or none)
  • The Vcore 3.2H has a kinematic called (hybrid_corexy)… but that kinematic is NOT the one used by the Vcore 3.2H. The vcore 3.2h uses a cinematic called (hybrid-corexy) “note the hyphen”, which is not (hybrid_corexy), the latter being used by Stratasys printers.
  • If I used that cinematic on my printer, it wouldn’t work properly; I might even risk damaging something.
  • To use the cinematic that vcore 3.2h uses, I have to redefine it, which I have no idea how to do. Alternatively, I could install RatOS, a fork of Klipper modified by RatRig, the creators of the project, to support their cinematic.
  • The other option I’m considering is installing RatOS, which already includes the cinematic, and deleting all the configuration files, replacing them with the ones I already have, but keeping the one that defines the printer, the one with the (printer) section.
  • nefelim4ag has already done this work; he has defined the machine.
More info, another option:
In my research process I’ve read that I can install (SankOilXY Klipper extended corexy module) which supports this kinematics… could someone confirm this for me?
