Where can I find klipper.bin
Printer Model: Ender 3 Pro with CR Touch
MCU / Printerboard: BTT SKR Mini e3 v3.0
klippy-3.log (10.5 KB)
i can not find out how to copy the klipper.bin file from the sd card. If i have the raspberry pi sd card with mainsail in my computer, what path can i follow to get the klipper.bin file extracted so i can put it in the mcu sd card?
Never Mind I Figured it Out
And where?
Other users may to know too.
I just renamed the found the file for the main board on github. It was an skr mini e3 v3
But WHERE did you find it?
firmware/v3.0/klipper/firmware-usb.bin
Then I renamed it to firmware.bin plugged it in to mainboard and then Klipper did the rest.
So you used a 2-year-old binary instead of compiling your own from the current codebase?
Yep, sure did.
I’ll just leave this here so you’ll know what to do when you start experiencing this error: MCU Protocol error caused by running an older version of the firmware
