WLED usage with Sonic Pad
Printer Model: Ender 3 S1 Pro
MCU / Printerboard: Sonic Pad
This may not be a klipper issue, but more sonic pad / moonraker:
I finally updated my SonicPad to the current version, I was several behind, and it broke my wled configuration in moonraker. I get this error now on fluidd:
Moonraker has failed plugins, please check your logs, update your configuration and restart moonraker.
wled
Validate your config against the current Moonraker documentation: Moonraker
Before the latest release, the SubSonic Pad used a Moonraker version that was roughly a year old. It is quite likely that things have changed.
My calls remain correct per the config guide, its almost like the wled plugin was removed or changed?
