Taz 6 Z Probe Calibrate No trigger on probe after full movement
Printer Model: Lulzbot Taz 6 IT-Works Titan Aero
MCU / Printerboard:atmega2560
logs-20230901-131154.zip (1.2 MB)
Hello all,
I have been struggling with this for a while now and thought i might reach out as my solution has not been addressed in other posts.
I have a Lulzbot Taz 6 with an Aerostruder. this printer has a push button style Z probe point that works just fine for homing, triggers no problem. However, when attempting a PROBE_CALIBRATE or PROBE_ACCURACY command it fails with “No trigger on probe after full movement”. Also the printer fails corner bed level process with “Probe samples exceed samples_tolerance” error. wiring seems in good condition/connected, haven’t tested them but since I haven’t changed anything on the extruder besides the nozzle (switched to Nozzle X), Z homing works and I never had issues like this with the Marlin firmware I just switched from, it doesn’t seem like it’s hardware related. I have tried increasing the z_min but it just puts a scary amount of pressure on the probe point while still failing
Hello @DeeJaay86 !
Have you tried a larger value for sample_retract_dist in [probe]?
The default value is 2.0.
